Company Logo Shop Now
Motor swapping and transmission issues
mikewood869
01-20-2019 07:42:08
After getting the 4500 running, we know we'll be splitting the 4500 come spring (there is a foot of snow) because of the leak somewhere inside the tranny. Since that motor is from a 1965- 4000, could I just swap a tranny to a 8 speed with independent, pto and a rear axle or would this make the tractor too long or short for the frame for the loader and hoe? Another things is, since we have to split the 3000 (to fix a issue with the pto), would a 4000 motor fit on the 3000 8 speed tranny (3000 has live pto, know that; wiring, lines, tank and other things would have to be swapped) or would this be too much for the 8 speed tranny from the 3000? Back to the backhoe, would swapping the the motor from the 3000 to the backhoe, make it too under powered? If I was to buy a transmission from 4, 6, 8 speed ag transmission, could that replace the torque tranny (I'm guessing that the 8 speed tranny would have non live, but no pto)?
mikewood869
01-20-2019 16:18:08
 Re: Motor swapping and transmission issues in reply to mikewood869, 01-20-2019 07:42:08
Probably wouldn't be good for the FEL and backhoe then. I take it that a tranny from a 5000 wouldn't work?
mikewood869
01-20-2019 12:13:29
Would a four speed tranny work from a 3000 on the backhoe?
Ultradog MN
01-20-2019 13:49:12
 Re: Motor swapping and transmission issues in reply to mikewood869, 01-20-2019 12:13:29
I'm pretty sure the 4000 and derivatives - because of the double reduction rear end - had a significantly higher output ratio on their transmissions than the 3000/derivatives.
It would physically bolt up but would be very slow. Howsomever, the plain Jane 4 speeds were known to be pretty fast.
Just picking numbers out of my ear here but maybe you'd have a top speed of 8-10 mph instead of the usual 15 or so.
For a TLB that might be ok if you just needed it around your property.
A 4 speed is the least desirable of all the transmissions of that era so you might be able to get one cheap. You would also need to get the clutch pedal and linkage and as stated, get the flywheel too.
Ultradog MN
01-20-2019 08:32:19
Lot of good questions.
I can answer a few.
Any 3 cyl engine will bolt up to any 3 cyl tractor.
I ran a 201 gasser in my 3000 for a few hears with no ill effects. It had a lot of power. Ford built a tractor like that. The 2110 LCG tractors were built on the 3000 platform and used the bigger 4000 engines with no ill effects. Of course the 3000 was single reduction rear end so if you get to ram rodding it you'll likely blow the rear end out of it. Also, the 3000 rear axles won't carry as much weight as the 4000 axle will.
The 3000 rear center housing is shorter by a couple of inches too so your hoe/loader sub frame won't just bolt on without a lot of mods.
Any transmission/rear end combo from a 4000 chassis is a direct swap with your 4500. I sold a 4400 trand/rear end to a guy that put it in his 4500. Made a nice package for him.
One word of advice: if you start swapping transmissions on a Ford make SURE you get the flywheel and clutch that came with that transmission!
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: DEARBORN SIDE DELIVERY RAKE CAN BE REPAIRED AND belly mount MOWER FOR PARTS ONLY.. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
