WTB: AXLE NAA-3011-B2
Tim PloughNman Daley RIP
I need a good used NAA- 3010-B2 (eng # NAA 3011-B2) front center axle for a friend's 841 with a 703 loader. This I think was the standard axle used from 1953 thru 1964. The axle on the 841 now has been brazed above the center hole where the loader splined shaft goes from crankshaft pulley to loader hydraulic pump. I don't like that and would not want to use the brazed axle when we have the loader back on the tractor. Currently have it split to fix the stuck clutch. Email is open.
Tim Daley(MI)
Forgot I have a NAA-3011-B and I also is looking for a NAA-3010-B, if I can find one I might let go of the NAA-3011-B, I just need to know if the NAA-3011-B is ok to use on a 1953 Jubilee. The original axle on the tractor now is got a bend in it due to the miss use from my brother running the tractor in to a tree. The bend is about a inch. Any one out there that can tell me the difference in the two number please chime in, before I go out and buy an other one the might be wrong.
Thanks
Jimmy
Thanks
Jimmy
I will let the one I have go, its a NAA-3011-B2. $120.00 plus the shipping around $70 to $80. Its already bead blasted and cleaned ready for paint. Let me know.
Jimmy
