I have spent about a year rebuilding a Wagner WM3 front end loader for my Ford 850. I had to replace all of the hoses, rebuild the spools, rebuild the pump, and replace the cylinders. I had a severe leak around the pump shaft as well. Here are some of the part numbers that may help someone else.
- Front pump shaft seal (ebay) #SKF7512, lip code R, style CRW1, .75" shaft, Nitril single lip, 1.375" Bore, 1.379" O.D., .25" width.
- Large o-ring inside of pump: #CNH87421144 (ebay), .139" thick x 3.109 I.D., 3.387 O.D.
- 4) rubber bushings for shaft hub. #AVS-X19-13 (Amazon), 1" O.D. x 3/8" I.D. x 1" tall. You need to cut the bushing in half to create 1/2" tall.
- Woodruff keys #606. 3/16" x 3/4" x .3.3" deep for pump and shaft.
- Titan-CFI Y WYE Strainer with 40 micron filter. (ebay) #YS80T-SS, 1" NPT 316 Stainless Steel Screen. You will need two 1" male to 3/4" female bushings to attach strainer.
- Use constant torque hose clamps. (at least 1-1/2")
- GForce 3" Bore, 30" Stroke, Tie Rod Hydraulic Cylinders (ebay). You will need to mount the new cylinder offset between the loader mounts
- All of the hoses I purchased from TSC.
Happy wrenching on your Wagner rebuild.
