Finally got the clutch unstuck. Had the starter out 3 times. Drilled a 7/8 hoe in
the housing and popped the disc with a long screwdriver loose 3 years ago.
Couuldn"t do it this time.
Advised to jack it up, get it spinning and drop the jack. Didn"t work and I took
off across the yard, clutch down all the time. Made a U turn and pulled up in front
of the shop at an idle in third gear. Stomped on the brakes to stall it and the
clutch let go.
I"m making a device to flip down on the pedal before haying. Meanwhile it"s blocked
down. Thought this might help somebody.
clutch let go.
