Hello all
Ford 4000 4cylinder gas. 3pt will not stay down when running reguardless of control posistion or draft. You can stop the arms with very little effort and push them down with maybe 50-60 lbs but they will raise all by them selves.
Been thru the valves and all rebuilt most of then as this was a basket case to start. Arms will lift full force when commanded and fill hold with machine off. Will lower and hold to commanded posistion as well when off.
Just when running will lift arms. What should I look for thansk
