Company Logo Shop Now
Order Ford 601 Parts Online
What is this Connector? FORD 601
EastTN
01-13-2019 14:48:19
I have been working on repairing/restoring a 1960 Ford 661. I have been having difficulty figuring out the purpose of the connector pictured below. It is in both sides of the differential. Any help would be appreciated.
[/img]
showcrop
01-17-2019 16:18:43
 Re: What is this Connector? FORD 601 in reply to EastTN, 01-13-2019 14:48:19
From where I stand when behind my 971 those little brackets are a lot handier than those chains.
Larry NCKS
01-17-2019 09:34:37
good way to lose 'em if you do any work in weeds or timber.
radara4077
01-17-2019 09:19:20
I have an 841, and I just snap my lynch pins onto my..."spacer chains"?... that connect the side arms onto the rear axle.
Ultradog MN
01-13-2019 15:08:35
That is where you ground the carburetor.
It needs an 0 or 00 sized cable.
EastTN
01-13-2019 15:00:04
Thanks for the reply. I thought that is what it might be. I saw something similar in the parts manual but it kept describing it as a linch pin. I thought it was a misprint. Also thought it might be used to ground something electrically.
Greg NE
01-13-2019 14:53:56
It is for holding your lynch pins when you're not using your 3 point hitch. You may have to loosen the nut a little and turn it straight up and down to use it tho.
Today's Featured Article - Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe. ... [Read Article]
Latest Ad: Wanted front suit case weights and rear wheel weights for a 1456 international. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
