Hey guys, new to the forum and wanted to see if anyone has seen this issue before. I have no hydraulics on the 3 point hitch. I recently put all new o rings in the three point assembly and made sure it was all clean. It has no rust and is in good shape. I put a hydraulic psi gauge on the test point under the seat on the three point cover and it reads 0 pounds at idle. It seems to jump up a pound when you rev up the engine. I took the rotary piston pump apart and inspected it and it looks like it has no wear. I put a rebuild kit in it anyways. I reassembled it and took the plug off the front top of it and it started pumping oil out when I started cranking it over so it seems to have a prime. I am just wondering what else could be causing no pressure.
Thanks for any tips.
