Company Logo Shop Now
Order Ford 2000 Parts Online
Ford 2000 lift problem 3PTH
bigdieselman
12-30-2018 15:58:18
helping a friend with his 2000 Ford with 4 cyl. gas The 3 point wont lift, pump has good pressure. Took the 3 x 5 plate off the front of lift cover and oil comes out hole to the right. We put compressed air in the port hole to the left of the check valve and the lift arms raise. Could the check valve in front of lift cover be stuck ? Tractor was setting for 5 years before he purchased it Thanks for any help
Dollar Bill
01-01-2019 03:06:11
 Re: Ford 2000 lift problem 3PTH in reply to bigdieselman, 12-30-2018 15:58:18
The unloading valve is beneath the top cover. These two posts discuss the unloader valve and may prove valuable to diagnosing the lift problems you are currently experiencing.
Post 1
Post 2
Dollar Bill
12-31-2018 02:14:41
If you aren't having issues with losing prime, the most likely suspect is a sticking unloader valve, especially when tractor sits for long periods.
bigdieselman
12-31-2018 04:13:15
 Re: Ford 2000 lift problem 3PTH in reply to Dollar Bill, 12-31-2018 02:14:41
OK where is the uunloading valve ? the pump is putting out pressure
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: DEARBORN SIDE DELIVERY RAKE CAN BE REPAIRED AND belly mount MOWER FOR PARTS ONLY.. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
