Ford 3000 hydraulic issues
sven6
I have a Ford 3000 that is having hydraulic problems. The 3 pt works fine but the bucket is very slow. I'll get a hydraulic pressure gauge and test a few junctions. My guess is it's one of the cylinders on the arms which raises the bucket that is leaking. Does anyone know what the line pressure should be?
Even with everything working the way it should, there is no loader made that will be fast using the factory 3000 hydraulic system.
If you're saying that it's running slower than it used to, then you may very well have issues with a loader cylinder, assuming the 3-point is functioning normally.
If it's a cylinder issue, the bucket will most likely roll back on its own when the control valve is in neutral. If it's a low pressure issue, the loader should operate faster when the bucket is empty compared to when it is full.
Max pressure should be around 2500 PSI.
Have you tried adjusting the flow control valve? FCV doesn't make a real noticeable difference on your 3 point speed as that cyl only holds a pint or two of oil but it sure will on the speed of a loader.
It's worth a try.
Screw it in for fast, out for slow.
Thanks to both of you guys. I'll check the valve. The reason I thought it might be a loader cylinder (which used to raise much more quickly) is one side seems to sag, like it's not getting lift equally on both sides. Does that make sense?
(quoted from post at 14:51:45 12/28/18) Thanks to both of you guys. I'll check the valve. The reason I thought it might be a loader cylinder (which used to raise much more quickly) is one side seems to sag, like it's not getting lift equally on both sides. Does that make sense?
That sounds like an internal leak in the one cylinder.
That makes sense. Sounds like you have a bypass on the piston internally on that side. Sometimes, if you have someone to help, with a stethoscope you can hear the bypass inside the cylinder. Usually an easy fix if internal parts are available, usually someone like Hercules hydraulics if you can't source them locally. If you are halfway mechanical, should not be to hard of a fix. Just be careful putting them back together so you don't cut a seal. Also..one little caveat, if you change that one side, change the other also. If you don't the other side will usually start leaking due to increased pressure to that side. Just a note. Did hydraulics for MANY years, from cylinders to pumps and motors. Let me know how ya make out. CJ
