I posted a few weeks ago about oil coming out around my shaft going out of the timing cover and covering my pulleys. I received excellent advice and I ordered the recommend front main crankshaft seal. When I went to instal it, I actually discovered that I had one, it was just covered in oil and grease, but once I cleaned it out, it was in good overall condition. I originally did not see it and I thought that part was missing. So apparently that was not the problem. I also was told to get the EAF 18183-A. I ordered what I thought was correct, but when I open the box, it is very very small and can't find a diagram where it belongs. I did notice on the box that what I have is the EAF-18183-B.
I assume that there is a big difference between the EAF 18183-A and the EAF 18183-B, or if it is the same thing, then I have no idea where it goes.
Thank you for your advice. Again, I as a stated before, I never seen a coil, taking apart a carburetor, etc. So diagrams or pictures help, I do have 100 hours working on this tractor with less than 10 hours of tractor time. As soon as I find the reason oil is coming out around the pulley shaft, I should be in business, well until something else goes wrong.
Thank you.
