willjohnfrank
Hey guys I have a loader problem. I am
adding a rhino model 2408 loafer on a
Ford 3000 tractor. I am using the
hydraulic fluid coming from the adapter
block that they make for the fords. I
have a CGA5A4B1 Directional Control
Valve, Two Spool, 4 Way,?as pictured
below. Now when I bought the loader the
cylinders were very rusted and the owner
admitted never actually using them. He
bought it to add to his tractor. He said
they may need replacing. I have never
done this but I bought all of the
fittings needed and the valve and
everything except mounting the loafer to
the tractor. When I plugged everything
in and started the tractor only the
cylinders that raise the loader would
work and the oil was shooting out of
the cylinders. Excessively. Would that
amount of oil and air escape cause the
bucket not to function? My question is
once I buy 4 new cylinders will my
problem be fixed or did I have something
plugged in wrong? My loader has the 4
hoses separated into 2 groups. One
controlling the bucket and one going to
the arms. There are 4 hoses to connect
to my valve. Does it matter exactly
where they go on the valve? Thanks guys
