JimBobBillyEarl
New User
Hi all.
I came into possession of a 3cyl Diesel Ford 4000 earlier this year. Per the previous owner it's "always" been hard to start, requiring a shot of starting fluid to start even on good days.
Recently it's sat about 4-6 weeks, and when I went to crank it the usual shot of starting fluid didn't seem to help.
Battery is fully charged, noted when I turn the key the voltage drops to low 8's.
Is this a normal drop? If not, what's a good troubleshoot?
After reading some similar threads on I've learned it's probably a good idea to replace the battery cables, regardless if they are culprits or not they appear corroded and the positive cable seems like someone spliced together two cables and electrical taped them together.
Any other suggestions?
Thanks in advance!
Thanks in advance!
