MirMiracle
New User
Hello. mountaindweller from norway here to ask you Guru's for assistance.!
Bought a 4610 2 weeks ago to use for snow plowing. it works wonders but the Wire/Knob in the cab you pull to stop the engine has been damaged and removed. so to stop i go out of the tractor and flip the diesel switch manually.
3 days ago i was in a rush so i went out and flipped the switch when i was done but i forgot to turn the ignition off.
so until the next day the tractor stood with ignition on and the Cab heater in full blow mode.
Needless to say the tractor was Stone cold Dead the next day when i tried to start it.,,,
Had help come with a battery charger for me, and charged it for 3 hours and it started no problem. everything is ok exept 1 thing.
I cant get the cab heater to start now. its dead. no air. no reaction from the heater controls in the cab.
i am by no means a mechanic but some *basic* stuff i know.
things ive done :
*Checked fusebox in cab right above the steering wheel, everything looks good. replaced the fuses that i think had something to do with heater.
*Checked wires from battery if they got damaged when i moved the battery to charge it. cant see any damage.
* found a new fusebox behind the battery with 4-5 fuses in it. all looked good.
*ive opened the roof to get access to to the Wiring JUNGLE. i have no idea what im looking at.
*Almost lost all hope.
All help would greatly appreciated.
I can provide all kinds of pictures. just ask.
English is not my native language so i am sorry if something is hard to read or understand.
Greetings from norway.
things ive done :
