Jubilee Loader
moving78
New User
I need to remove the loader on my 53 Jubilee before splitting it. It's my first tractor, and I'm not sure how to detach the hydraulic pump in the front (see attached photos). Also, can I remove the loader without draining the hydraulic fluid? Thanks!
Take the grill off and it should be fairly straight forward once it's off.
Take the bolts out on the coupler and the bolts out that hold the pump to the housing and lift the pump up and remove the shaft. You don't need to drain it but if you are going to put it back on I would. There is a big pin that needs to be removed that holds the the frame to the housing. I just removed one on an 8N that I am going to start next, a little different but basically the same.
On my Jubilee, I unbolt the pump mount and pull the pump, shaft
and all right out the front. The shaft is just splined where it goes
into the hub on the front of the engine.
