vvfarms
I don't see hyd pump on left bellhousing,is pump inside? It has rockshaft & control lever. Thanks Vaughn
Trac # BB70003
model BA414C
unit 8G01B
eng 132094 8F25
trans 8F27B
rr axle 8F14B
hyd pump 8F22B
hyd lift 8F30A
EGNN 9401631BA
Yes, the pump should be in the right side if the center housing.
Your model number, model BA414C, says that it is a 2910 with a diesel engine, independent PTO and an 8 speed transmission.
All tractors that had the double reduction gears and inboard wet brakes in the rear axle that also had independent PTO had the pump in the right side instead of up on the engine, with the exception of the 3 cylinder 4000 models that had the S-O-S transmission, as those had the PTO clutch inside the transmission that ran off of the trans pump instead of running off of the back half of the 3 point pump inside the center housing.
