Yudt06
Hey guys (especially Soundguy haha)
I have obtained all the proper brackets (esp for the plate that
mounts under the steering box) and selec-trol valve to mount
my 711 loader on my 54 NAA. Can you guys please post so or
send me some photos of the Brackets on the NAA so I can
properly install them.
Thanks
Ryan
Since Chris has not responded yet I will post a couple of photos. Mount you trans plate bracket under the steering box then bolt the trans hip bracket using the holes in the plate bracket and the lower hole in the trans case
<a href="https://imgur.com/ZSVyd7Q">
ZSVyd7Ql.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/lluJ4af">
lluJ4afl.jpg" title="source: imgur.com"
</a>
Mount your front brace bracket that help support the front bracket. This is the bracket with the two countersunk holes. Take your two axle carrier nuts off and put the counter sunk bracket on. Use two nuts off your rear wheel to secure. Then bolt your front bracket to the lower holes on your axle carrier and bolt the brace support bracket on the to front bracket. The small two hole bracket with the bushings mount under the trans. The last bracket slides over the bushing under the trans and connects to the loader frame
<a href="https://imgur.com/yHxKnG7">
yHxKnG7l.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/DDuVye0">
DDuVye0l.jpg" title="source: imgur.com"
</a>
<a href="https://imgur.com/70YpzQS">
70YpzQSl.jpg" title="source: imgur.com"
</a>
Thanks for all the info. Can?t wait to get mine mounted. It?s been a two year process obtaining all the parts
