Tim PloughNman Daley RIP
The debate over ethanol in gasoline will go on forever but the truth is you do not need to run it in your old Ford tractors. You are right about one thing -farmers would run whatever was available back when. Kerosene, alcohol, white lightnin', et al, were used in a pinch. You are also kidding yourself and wasting your money on 'snake oil' products like STABIL -it doesn't improve anything except maybe clean some gunk. It is mainly mineral spirits and you get the same thing from paint thinner and charcoal lighter fluid. I have yet to see any hard data to confirm this or any other 'additive' improves anything. Since ethanol free gas costs at least a buck more per gallon, another reason to think about where you spend your hard earned $$$. My 8N sat for a year. This past summer I went to start her up, installed my battery that had been on a Battery Tender since I parked it, and it fired right up and ran fine with the full tank of gas that I put in it when parked.
Tim *PloughNman* Daley(MI)
