Author |
[Modern View] |
5bfarms
11-17-2018 06:44:19
1 have a ford 7600 with a loader w/power beyond valve installed. my hydraulic pressure to loader and rear remote is bypassing. both locations will build pressure to almost 2500 initally and then drop and build up less than 2500 and drop contionsuly. any one have this issue
Sean in PA
11-18-2018 04:01:11
Re: ford 7600 loader and rear remote hydraulic problems in reply to 5bfarms, 11-17-2018 06:44:19
I think that he meant "both the pump and the filter", not "both pumps and the filter".
sotxbill
11-17-2018 19:35:09
both pumps??? do you have two pumps running the hydraulics?
if so you have the ccl system. If your talking about the power steering pump and the rear hydraulic pump, then disregard.
If you have the single side mounted pump, one of your check valves is sticking open and dragging badly before it closes...
Normally I see the pressure climb to 23/2500 and then the needle on the gauge vibrates between 2100 and 2300 plus or minus... the internal valve in the pump will move very fast creating the vibrating gauge. So either that safety valve is sticking or the one in the remote hydraulic control valve is sticking..( assuming you have the external remote control valve on the tractor).. If you have a ccs then it more complex but as others said, it came later than a x600 tractor..
RodInNS
11-17-2018 13:36:37
Change the filter to start with... but probably the pump is the issue. Rod
5bfarms
11-17-2018 15:09:20
Re: ford 7600 loader and rear remote hydraulic problems in reply to RodInNS, 11-17-2018 13:36:37
Sean in PA
11-17-2018 12:42:57
I thought that the CCLS hydraulics didn't come out until the xx10 series or maybe the xx30 series?
David G
11-17-2018 18:04:12
Re: ford 7600 loader and rear remote hydraulic problems in reply to Sean in PA, 11-17-2018 12:42:57
RodInNS
11-17-2018 13:35:19
You are correct. CCLS was a 10 series update. Rod
5bfarms
11-17-2018 15:11:16
Re: ford 7600 loader and rear remote hydraulic problems in reply to RodInNS, 11-17-2018 13:35:19
its a block that is installed between rear hydraulic valve and top plate to supply fluid to the front end loader
David G
11-17-2018 09:51:54
power beyond block? I thought these were CCLS?
sunbeam
11-17-2018 09:20:56
How old are the hydraulic filters?
5bfarms
11-17-2018 15:12:23
Re: ford 7600 loader and rear remote hydraulic problems in reply to sunbeam, 11-17-2018 09:20:56
both pump and filter are not a year old
