The Traction sleeve coupling is too far on front shaft to engauge transmission...I got stuck and turned the lever to the right to tow then after re starting tractor I guess I turned the lever too much.. I opened the housing and can see the coupling but can not move. the front shaft will move forward and reverse when tractor is running and proper gears are selected using the handle on the selector assembly... so I do not think a clutch went bad etc...
Not a lot of space to get any leverage on the coupling..impact wrench from top??
Thanks Sue
I have a picture but somehow can't post it here
Thanks Sue
