3000 oil pump drive
KYCASE1
What is the best way to remove the oil pump drive on a 3000 diesel. It has what looks like a freeze plug covering it. Does this remove and does it usually get destroyed when in comes out. I just don't want to damage anything. Thanks
Yes, you'll need to dig it out of there and it will be destroyed in the process. It's just like a freeze plug, except that you can't rotate it in the bore to get it out like you can most freeze plugs.
