861-Oil level in steering housing?
Blueox4
Which one of these bolts is where the oil level in the steering housing is checked and or filled? I?d like to check the oil level while the hood is off.
Thank you!
The one in the middle sticking up is actually supposed to be a vented cap plug. Everyone says to use cornhead grease in them per a service bulletin from Ford years ago. Fleabay sells vented caps some with just a tin cap on top and some that are little brass beads knid of like the old fuel filters for carbs. YT might carry the plugs.
