So the replacement radiator looks great and bolts up with the existing fan shroud. The problem is the lower radiator hose won?t fit on where it
needs to fit between the shroud and the lower radiator spigot. It?s too tight. My first instinct is to cut a strip out of the shroud so I can fit the hose
down over the spigot. Is that the correct way to modify the original shroud to fit aftermarket radiator? I don?t have any place that can recore my
original radiator so I had to buy an aftermarket.
