KYCASE1
Having trouble with my 960 gas. When I try to throttle it up it starts to pop back through thru the exhaust. I have installed new points and condenser cap and wires. I have also rebuilt the carb. It seems to get better after it warms up but never goes away completely. The tractor sets a lot and is never used hard. It starts good and idles good.It almost sounds like a valve is not seating rite. Anyone have any ideas. It's got me scratching my head.
I'm with SC, sounds like you may have a wire crossed.
For your comparison:
I agree with Larry. If it starts and idles good and only has problems when increasing rpm's, I would think that you need to look at the timing advance mechanism.
(quoted from post at 06:55:40 11/08/18)
Soory guys! How does "it start good and idle good" with wires crossed?
He has fueling issues.
Sorry Larry, all I can say is try it. You will probably be surprised.
(quoted from post at 18:56:14 11/08/18)
Somehow, I doubt that very much. If he's crossed wires he's got an engine running on two cylinders. I don't think he'd call that "idling fine."
Furthermore, I've been there and done that,. Don't think it'd be any surprise at all
(quoted from post at 17:17:38 11/08/18)
How long ago Larry? Three weeks for me. Fresh on my mind.
close the fuel shut off valve. take your fuel line loose. squirt some w-40 in there and button it up and try it. even though you over hauled your carb it sounds as though your needle valve is sticking. wd-40 is an oil based liquid that will stop that. give it a try. not going to hurt.
