Company Logo Shop Now
TractorLinks.com
Order Ford 860 Parts Online
Advice needed on 860 Power Steering surprise
Blueox4
11-08-2018 13:50:50
So I open up the power steering oil reservoir on my 860 and this is what I find. Believe it or not the power steering seemed to be working before I parked it for radiator replacement.
1) how do I flush this out of the system?
2 is the filter inside the reservoir supposed to be canted like in the pic? I loosely grabbed it and it seems to be attached or maybe stuck in that gunk.
third party image
Dean
11-08-2018 13:57:40
 Re: Advice needed on 860 Power Steering surprise in reply to Blueox4, 11-08-2018 13:50:50
Best way I've found is to jack up the front and disconnect the lines at the cylinders. Don't fail to mark the hoses.
Turn the wheel side to side until no more oil comes out.
Refill the reservoir.
Repeat until oil comes out clean.
Replace the filter.
Replace the lines.
Top off reservoir after starting and operating through full range several times.
Repeat process if desired.
Dean
Blueox4
11-09-2018 02:44:01
 Re: Advice needed on 860 Power Steering surprise in reply to Dean, 11-08-2018 13:57:40
Should I refill with ATF fluid or regular power steering fluid?
Dean
11-09-2018 08:04:52
 Re: Advice needed on 860 Power Steering surprise in reply to Blueox4, 11-09-2018 02:44:01
I use CNH Ambra or other hydraulic oil that meets the Ford spec.
Dean
Blueox4
11-08-2018 14:34:16
Thanks a lot Dean! I really appreciate your and everyone heres help.
