For breather try Section 3 at Messicks link in my previous post, #15, part number 87790411. You probably won't like the price $61.50 and when it says 3-7 days instead of in stock who knows if you can even get one.
I have a hard to find reusable filter assembly and the vent(I think I know where it is). Its on fleabay (232996035274) if you want to see it. The vent is not in the picture but its complete. Emails open.
(reply to post at 08:23:01 11/08/18)
s I am a novice at this I am baffled that the hydraulics for the loader do not work. I took pictures of the pump as I took it apart and I thought I put it together properly. Fluid level is good. As the loader was working good until the splines stripped I wonder if the filter may be plugged. I did not drain the system with the drain plug I took the rubber hose off. I did get one belch of fluid back through the vent but after that nothing.
