73 4000 201 engine oil level twice normal on dip stick.
Return lines are all external, dumps into tank filler neck, no stand pipe.
I suspect front injector pump shaft seal for leak into crank case. Could this fuel
in the pan be a result of not closing the fuel tank shutoff valve on shut down or is
it happening while running? Thx Jim in Baton Rouge
