Dieseltech
- Location
- Akron, Indiana
Have a 1964 4000 gas row crop with SOS trouble, no park, only gears that work are 5,6,7,8,9, and 10. Band 2 pressures per the IT chart are 170 PSI on R2,R1 N,1,2,3,4,9, and 10. Band 3 has 170 PSI on 5,6,7,8,9, and 10, 0 PSI on Park,R2,R1,N,1,2,3, and 4. Pressure chart shows Band R2 should be pressurized too, but I'm not sure that's right as the FO173 chart shows Band 3 is applied with spring pressure, and released with oil pressure. I suspect band strut out of place, or band broken, or some other trouble. Tried the band adjustment screw, made no change at all. Bought the tractor at auction, shows 4855 hours on the working tach. Say the strut is out of place, how much work is involved getting it back where it belongs? Does the third band break? Wondering if it should be repaired or scrapped. Has new rubber on the rear, could be parted out possibly. Thanks for all input.
