Need Front Weights 1965 Ford 4000 3 Cyl. Diesel
JRB.ACWD45
New User
Restoration tractor: I'm needing three (3) Ford OEM front pad weights, whatever they weighed, hopefully around 80 lb. each.
As an option, if anyone knows where I can find an after market bracket that matches the bolt pattern, I will go that route and try to find three (3), eighty (80) lb. Ford suitcase weights.
Thanks, JRB
Where are you located? There are some of those weights (5?) on either the Northern WI or Eau Claire craigslist. I had a welding
shop make a copy of my 4600's weight bracket for my son's 4000.
There were some of those
"pillow weights"
in Michigan
There are also some in NW WI CL but they
are the 6000 style.
https://northernwi.craigslist.org/grd/d/tra
ctor-weights/6707307037.html
Click here
Here are some front weights in Braselton, GA that are a bit closer maybe. https://athensga.craigslist.org/grd/d/tractor-weights/6728218287.html
Another in Columbus, GA: https://columbusga.craigslist.org/grd/d/full-set-ford-tractor-weights/6683698418.html
One more in Lovejoy: https://atlanta.craigslist.org/sat/grd/d/tractor-weights/6712361163.html
None of these are mine.
I have a set of 4 in Oregon
