I have a 1964 ford 2000 industrial backhoe , gas 4 cylinder , and 4 speed transmission. I had trouble with first gear locking in while trying to change to reverse. long story short, the gear on the top shaft against the bell housing busted and split apart. the shaft is broken I suspect since the shaft and gears will move up and down. I do not think the busted gear held two shafts together.
My question is where would be best to split tractor to repair ? never done a split except to replace the clutch, pressure plate, and bearing. I split it at the back of engine for this. thanks for any replies. randal
