Ford Tractors Discussion Forum |
68 ford 5000 loses power after an hour or so
Author |
[Modern View] |
samkrav
10-21-2018 07:35:59
Hi All. I have a 68 ford 5000 diesel that I use to shred and disk with. It started losing power after about an hour into working. After I let it cool down, it will run for another hour or so and same results. The engine also seems to miss and idles down. I am thinking this has something to do with the injector pump however saying that, I have absolutely no experience with diesel engines. After researching a bit, I beieive it has a SIMMS injector pump.If anyone has any ideas it would be greatly appreciated.
Chris in SK
10-22-2018 13:55:35
Re: 68 ford 5000 loses power after an hour or so in reply to samkrav, 10-21-2018 07:35:59
I'm going with blocked screen in the tank. Next time it runs rough, stop and take the supply line off at the lift pump and if you don't have a good flow of diesel, blow back up the pipe until you hear bubbles in the tank, then see it you then get a good flow out of the pipe. You will have to bleed it then. If it is trash plugging the screen you'll need to flush the tank.
Danny Prosser
10-22-2018 09:43:33
If it's like the Simms pump on my 65 3000 look on the top and it's a small round cover with a nut on top of it. It looks like the oil fill breather cap on smaller fords like Jubilee's and 600's. Take that off and look under it. There's a wire mesh filter like in oil bath filters in it. Mine would start and die so I changed the filters bleed it and it still did the same thing. After every diesel mechanic I know said it's got air in it keep bleeding it. Well after a day of that I started looking for another reason. Pulled that off and it was completely caked full of gunk. I cleaned it but it back on and it fired up.
samkrav
10-21-2018 18:15:58
Thank you for the reply. I have been researching the Simms injector pump and did read about today actually. Going to try that this weekend when I get back out to the farm.
Dieseltech
10-21-2018 17:12:34
Sounds like fuel supply. Could also be the cap vent is plugged, no fuel out after awhile if air can't get in the tank. Next time it acts up shut the engine off, and listen for air rushing in when removing the cap. Neighbors White 2-155 died last spring after 1/2 hour running do to a plugged cap vent.
Destroked 450
10-21-2018 12:10:09
Have you checked the oil level in the inj pump. Those Sims pumps have their own oil reservoir for lubrication.
Bern
10-21-2018 09:33:35
Those injection pumps are pretty rugged, so I'd look elsewhere. I suspect you either you have trash partially blocking the screen in your fuel tank outlet, or else, if the screen has come off or been removed, you have the same issue going on inside the lift pump, plugging up the check valves.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
It's Alright Where It Is! - by Anthony West. I have a tale of a different kind to tell. Whilst rooting in the hedge bottoms this week I had cause to visit Chapel lane Farm, the home of an eccentric gentleman by the name of Austin Kendall. I had heard rumours that an old Case Model C was languishing away in the back of one of the outbuildings there. So off I went in search of what would turn out to be a very rare and unusual tractor. Mr Kendall is an excitable chap to say the least. He is amongst the last of a dying breed of farmer who
... [Read Article]
Latest Ad:
Fiat 800E/ AgriPower 8000 Tractor for parts. Engine burned, but didnt get the injection pump or hydraulic pump. Back end of the tractor still ok, sheet metal is still there. Good for parts.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
