Parking Brake Control Handle
OBwan
78 Ford 3600 diesel
The parking brake control handle has decided to take a dump. The handle slides up and down on the rod but wont separate from the rod. The parking brake will work if I push down on the brake pedal and pull up on the rod, but the handle doesn't do anything but slide up and down and rotate.
Is there something that secures the handle to the rod or is it replace the handle and rod as an assembly?
