OregonAaron
So, I finally got my tractor up and running again. Too many other projects needed completed, so it took some time- also I have a '41 9n that I used while the 2000 was down. Anyhow, when I first acquired this tractor, the fuel pump was by passed and made gravity feed, the carb was severely messed up and had jb weld repairs on it, and many other band aid fixes. Now it has a brand new zenith carb, new fuel pump, oil change, new fuel lines and tank valve. The rear axle/hydraulic reservoir was 5 gallons low, now its topped off. Now it runs great, like a whole different tractor. The governor rod still needs a final adjustment, it will get one when my new manual arrives. Also the rod end on the carb linkage needs replacement- the previous owner zip tied it together and it is now too worn for zipties... I will try to find one locally, however our local new holland dealer closed their doors. All in all, it runs amazing, i have a few loose ends- but that's no big deal.
