tiresharkdb7
Solenoid is sticking... when I push the start button, occasionally it will keep trying to start even if button is released and off/on switch is moved to off. I have to hit it with a screwdriver and then it stops trying to start.
Local tractor shops dont have it. I have a bunch of old lawnmowers laying around... just curious if I could use one of those 4 post lawnmower solenoids to replace the one on the tractor, or not.
It's an 850, and it is a 12 volt.
If you guys think a lawnmower solenoid wont cut it, I will check with napa and see if they have one... otherwise I will order it.
From searching threads, I think this will work on my 850. Thanks for any input.
https://www.napaonline.com/en/p/ECHST542
