Edwin Rambuski
New User
Be careful if you buy this part from Yesterday's Tractor:Ford 601 Water Pump - with Press-On Pulley. It will fit a 601 fine, and looks just like the original. However, after I installed the pump and started the tractor, after just a few minutes the "Press-on Pulley" with the fan attached flew off the shaft of the water pump and in to the radiator. You can guess what happened to the radiator. I am not sure of the manufacturer but the package said it was made in Turkey. I am waiting for Yesterday's Tractor to address the issue. I am not sure I want to use the same pump. Are there other water pumps out there that may be more reliable?
