Is this the right starter switch button for my 850?
Working on tractor and somehow fried the starter switch button. When I press it, it only spits out 4 volts to the solenoid.
Here is a picture of it... I broke one of the screw terminals off when I was taking the wire off.
https://i.imgur.com/2PkQpjw.jpg
Will this TSC button work on my tractor? Thanks.
https://www.external_link.com/tsc/product/cambridge-starter-button-sealed-switch-20a-12v-dc-720w?cm_vc=-10005
That looks like the solenoid button for the preheaters on a diesel. Starter button should be on the gearshift plate.
That looks like a starter switch for an 01 or early 000 Select-
O-Speed tractor. Are you sure your tractor is an 850? Or might it be that an 850 transmission was transplanted into a tractor that was previously an SOS tractor?
Short answer is no.
Your switch should look like this one and be in nearly this location if it's a Ford 850.
Obviously this is a four speed transmission, not the 5 speed a Ford 850 would have.
Don?t know what that first pictured switch is, it is not a normal 100 series starter switch.
Can?t get the TSC link to open up.
The picture Royce has here is what your switch should look like. In a 5 speed it is slightly more to the left on the plate if I remember right. Haven?t sat on mine the past few months, some years I drive it more days of the year than not.....
Paul
