OregonAaron
So, I finally had time to work on my tractor and I just replaced the carb with a brand new zenith and put in a new fuel pump. So apparently the linkage for the carb needs to he adjusted since the governor runs into is housing at just off idle. So what is the procedure for adjusting the carb linkage (I need to make mine alot longer). Also, those darn flared fittings on the fuel pump- my new fuel pump came with new fitting and I bent new fuel lines out of 5/16 brake line. So both halfs of the fitting are new, I tightened them very tight and they leak... both sides leak the inlet and out. What's the trick to these darn things? I have never had a brake line leak!
