marcusmerritt
Ford 2000; 3 cyl gas; 4/1 trans....for some time now the throttle will not keep the engine at a set speed. Throttle lever moves easily but engine speed does not change until the lever is pulled most of the way down. Wide range of low to medium speed does not seem accessible. When the lever is pulled all the way down to rev up the engine, the lever will not stay at that speed, it migrates back up to a low idle as if there is some spring action going on. I assume there is some issue with the throttle linkage or maybe wear in the mechanism. Any ideas on what would cause this? Thanks.
