Ford 4000 3 cylinder gas 1965
Jkfarm
New User
Hi I'm new I apologize if this shows up
twice. I would like some help on if I have
high and low beam lights 12v if I can plug
them in the harness or if I need additional
wiring. The switch I'm using is push, pull,
pull (C5NN11654A) withe the terminals
marked blank,A, H, R. Also looking to see
how to wire the fuel gauge. Thanks
Welcome to the forum.
While I'm not certain I think you'd have to add wiring, change the switch, and change headlamp sockets to accommodate low/high beam headlights,
On an IH tractor or that vintage A, H, R would mean All, Headlights, and rear Red . . . I think. We'll see if others have better knowledge of your tractor than I do.
(quoted from post at 17:07:46 10/11/18) Welcome to the forum.
uropean version would have wiring for high and low beams and a switch with more positions and terminals.
Thanks for the quick response, the
headlights I purchased came with double
filament bulbs and 3 wires I thought they
were 2 wire 12v cause that what pictures
the sell had. Thanks
The high low beam european lights use a rotary three position switch, you also have to run another wire from the switch to the headlights, the standard US wiring harness only has one wire going to the front lights.
Thanks for all the help I decided to run an extra wire from the A terminal on the push, pull, pull switch to the hibeam light and it worked great. On another page any one got a place I can get the wire setup for the Guage cluster and fuel sender hook up. Attaching a pic of cluster
