Ford 7610 Rear Engine Plate Gasket
Hurst
I am replacing the clutch on my 7610 (1986 model), and it has the 268 block that does NOT have the removable rear seal housing. Do
I still need gasket C7NN6N008B? I took it apart, and it had this gasket between the rear plate and the engine block. I always
thought that gasket was for the later engines that had the removable seal housing.
Hurst
Gasket C7NN6N008B goes between the back of the engine and the separator plate the fit between the engine and trans.
This gasket is used on all of the models up to 12/86.
The later engines used a different gasket that goes between the plate that holds the rear seal and the engine block.
Ok, thank you, just what I needed to know! I will make sure I get one of those gaskets with the rest of my parts.
Hurst
