tiresharkdb7
Was draining the transmission fluid and refilling... was spraying carb cleaner down onto the gears to help flush any crud out, and the little red plastic nozzle (looks like a tiny red straw) on the carb cleaner can fell into the port.
Is this a problem? I'm assuming since it is plastic, it will just get chewed up by the gears, and settle in the bottom. Think it will be ok, or do I need to try and get it out somehow?
