Dropped something in transmission fill port. Problem? 850
Was draining the transmission fluid and refilling... was spraying carb cleaner down onto the gears to help flush any crud out, and the little red plastic nozzle (looks like a tiny red straw) on the carb cleaner can fell into the port.
Is this a problem? I'm assuming since it is plastic, it will just get chewed up by the gears, and settle in the bottom. Think it will be ok, or do I need to try and get it out somehow?
