NHbalerman
My 5000 tractor is having pto problems,you have to rev up the engine for it to work or for the brake to work and when it gets hot or after using it for awhile it just
worse,just using it on the balewagon all it does is turn the hydraulic pump on the balewagon,Im thinking it is the pump,it has been awhile since we used the lift or the
remotes but last time they were working good,and the pto was acting this way,Is there anything else I can check before buying a pump? Thanks
