I am looking for a "Good" used cam, or a used one that's good to be ground.
I need a cam that will work in a 172 diesel, if you have one, please post, pm, or e-mail me, with cost.
"Good - means put in and go.
"Good to be ground" - Means that it has good bearing journals, good key way, good pump drive gear. one that you have, and don't know if it's good, or just has a journal, or two that's lightly worn, nothing bad.
Does anyone know, if the cam from a 192 will work in a 172. Are they the same? I know someone that has a 192 cam, but can't find anyone that knows if it is the same.
Thanks, Pat
Thanks, Pat
