loader bucket wont work
I have a 1954 NAA with a loader bucket that the cylinders were leaking.I reseal them put everything back together but now the bucket won,t go up or down .It was working before I took it apart but slow.What could be the problem.
I'm not a hydraulic expert, but it sounds like you need to bleed the air out of the system. Some of the others will come along and tell you exactly how to do it, I would bet.
Is resivour full? Pump turning? Not being smart. Cyl take minute to fill. They will bleed themselves by cycling. Valves just don't go bad over nite.
yes full of hydraulic oil and the pump is turning.The reason I said the spool valve might be bad is the handles seem real loose not tight at all.I think I might have to replace some o rings in the valve.
