I bought this '66 Antwerp 3000 diesel a few months ago and I just bought a 730 loader to put on it. I hadn't noticed before, but the holes in the bolster where the front bracket would bolt up appear to have had bolts broken off in them and something welded to the bolster.
I ground it down to where I could see the bolts in the holes and figured with some good penetrating oil, some heat, and a good extractor the would come right out.
Well, so far, that plan isn't working out. I got the holes drilled all the way through the bolts and filled the cavity with penetrating oil. Put a propane torch to it and got to work with the extractor. It bit good but the broken bolt wouldn't budge. I ended up breaking the extractor off in the hole. I didn't have the proper size punch or a big enough hammer last night, but I believe I can drive the broken piece through the hole and try again with a bigger extractor or just drill them out completely and re-thread the holes.
I've not given up yet, but I'm thinking of my options. I've seen several posts by Ultradog MN about the two different bolsters. Can I go to the late model, "heavier" bolster? I figure it will bolt up, but will my early model pin and axle work or will they need to be changed, too?
