WildcatFord
New User
I have a Ford 641 with a charging light that won?t extinguish. Voltage regulator was recently replaced, and the charging system seemed to work for a few weeks.
Tried repolarizing the VR by shorting across the VR field and battery terminals, and the charging light went out for a little while, but started staying on again later in the day.
I can motor the generator, so I don?t suspect any issue with it.
Given that repolarizing seemed to solve the issue for a bit, I?m suspecting the replacement VR is bad. Any suggestions? Should I go ahead and shell out the cash for the NAPA ECH VR951?
