Tenpen
New User
Hello, thanks in advance for help. Im new and learning by finding as I go thru a jockey parted 600 with a 132" is offering plenty of part familiarization and replacement. My newest issue is the carb is for an 800, it is the tsx 593 and I am not familiar what factors this will cause for a 600 system. The tractor has ran plenty enough like this is already but lately gave me reason to tune up the carb and oil bath system. Is it realistic to continue using this carb? Thanks again!
I thought a TSX 765 went on an 800 series. It is probably fine as long as your exhaust pipe aint too black. It usually relates to which manifold you have on it, they were made a little larger in the later years with a richer mix carb, giving them more HP. I think theres a casting date or part number on it somewhere if you can read it. Casting date will tell you which manifold you have.
If it ain't broke, don't fix it.
Are you sure your tractor is a 600 series and not a 601 series?
If it's running fine then you can leave it. It may use a bit more gas than it would if it had the proper carb, but other than that it should be fine.
