Need help with bushing on shift linkage.
mwelch2583
New User
The clutch linkage on my 2600 is pretty frozen where the throwout bearing shaft goes through the case. Tried multiple rounds of heat and rust penetrant with no change. Anyone know this part # think my only option is to hammer shaft out, replace the bushings and clean up the case and shaft. Thanks
Heat it up and stick a candle to it. It wont go up in smoke like penetrant and it will wick into it, and its slippery when hot.
(quoted from post at 16:55:50 10/02/18) Heat it up and stick a candle to it. It wont go up in smoke like penetrant and it will wick into it, and its slippery when hot.
Worked great, thanks for the tip.
