The white set (actually Ford light gray, but for the sake of simplicity)
is what I believe are commonly referred to as the heavy AG set.
Each pie segment weighs 42 lbs. Measurements in the pictures.
The other set is what I believe are commonly called the heavy
"industrial" style. Each segment weighs 38 lbs, so not the light set.
Measurements also in the pictures. The rusty set is one inch shorter
from the outside edge to the mounting hole, making the outside
diameter when assembled about 24 inches. The white set being
an inch longer measures 26 inches across when assembled.
I think the rusty set would work with PA rims. The white ones
would fit but not allow adjustment of the PA rims. Neither set
would work on a 24 inch rim unless the rims were adjusted all
the way in and the weights were allowed to sit outside the rim.
Sound right?
The rusty ones will be on their way to the sandblaster soon.
Sound right?
