Wanted to buy, used
TinCan
I am looking for a "Good" used cam, or a used one that's good to be ground.
I need a cam that will work in a 172 diesel, if you have one, please post, pm, or e-mail me, with cost.
"Good - means put in and go.
"Good to be ground" - Means that it has good bearing journals, good key way, good pump drive gear. one that you have, and don't know if it's good, or just has a journal, or two that's lightly worn, nothing bad.
Does anyone know, if the cam from a 192 will work in a 172. Are they the same? I know someone that has a 192 cam, but can't find anyone that knows if it is the same.
Thanks, Pat
Hey Pat, I had to do some fencing yesterday, didnt get a look at the cam yet. I'll try to get to it today. I am pretty sure those 4 cylinder
192 industrial parts are interchangable with the 172.
I have a used cam that out of an early 1960's diesel motor. It fall in the "good to be ground" category. It is factory marked as diesel.
$75 delivered
Roger that,
Thanks, I'll get to you on this, but I had talked to someone right after posting, about a drop in and go cam, and I told him I'd wait till I hear back from him First. Does not mean I made up my mind, on any cam yet.
Thanks, Pat
pomester,
Thanks, I just bought it. Now I just need to wait till I get it next week.
Hopefully it's a good one, and I can just use it without having to grind it.
Thanks, again, Pat
